sys fan question.
triarii3
I bought an Nzxt Tempest case that doesnt have any fan controller. sooo....is it possible to control the case fan speeds in a software so the 6 fans on my case won't need to run at 100% speed and sound like a freaking SCHOOL BUS!?? lol
please help a nub out with!!!
You can use splitters from the fan headers on your motherboard, but I would recommend attaching at most 3 fans to one motherboard header, depending on the speed of your fans. If you're using more than 2500 RPM fans, then two fans or less per header.
Then you can use a program like Speedfan to adjust it. Provided your motherboard supports it.
