Synchronized PSU powering
n00btard
So... I'm going to get a real job this summer, which should fund my water-cooling project nicely. I want to watercool a system in a Fragbox 2, but since I've decided on an Innovatek XXD kit, there isn't much room in the box as is, and I don't really want to do anything to the case, short of removing the top handle.
So I decided on using a toolbox to house my watercooling components, such as the res, pump, rad and stuff. Then I realised that there wasn't really a way to power the components inside that aforementioned toolbox without sticking a second PSU inside, since I was going to need more than one power connector to power everything inside that toolbox, such as fans, pump and lighting.
Since flicking the switch on the back of the power supply probably won't turn it on unless the mobo connector was shorted out (like what people do to get their pump on so they can fill/bleed their loop) and I don't want to give my PC a reach-around each time I want to turn it on, is there an after-market mobo plug shorter thing I can buy and integrate it into the front of the case? Or is there a way to get both PSUs to turn on when I press the power button?
