I wasn't sure which forum was most appropriate for this post since it has to do with PSU's as well as video cards.
My question is, what are the common symptoms when a PSU isn't powerful enough to power a SLI system?
My current rig (in sig) runs every game I throw at it without a problem except Oblivion. In Oblivion, when in full screen, the screen flickers like a strobe light and I get what looks like artifacts. The odd thing is, when I use FRAPS to take a screenshot or make a video, the flicker and artifacts aren't recorded. I scoured the Oblivion forums looking for others with the same symptoms but noone else has reported these symptoms. As long as I run the game in windowed mode, it runs fine. This problem only occurs when I try running the game in full screen mode.
I do have an Enermax Liberty 620 on the way from zipzoomfly so the Neo 480 is only a temporary PSU. I'm just hoping that the problem is simply insufficient power and the Enermax will resolve it.
I have tried numerous driver versions using driver cleaner between each install including the Oblivion optimized drivers released on Wednesday. They have no effect on this issue. Any info is appreciated. Thanks.
[edit] I forgot to mention, The only other items I have in the system is a SB X-Fi platinum, 1x IDE 7200 RPM HDD, 1x SATA HDD, 1x floppy drive, 4x 80mm fans and 1x 90mm fan. No CCFL's.
