Symantec Ghost 8 - Bootable Network CD's
cbachor
I use ghost to image computers via the network at my office and currently what i have to do is boot to a bootable floppy disk created by ghost which contains that computers network card drivers on it and then connect to the ghost cast server and then proceed to image the computer. what i would like to do/know if possible is if there is some way i can do the same thing except have a bootable cd. the reason i would like to do this is beacuse the floppys go bad quite often and you cant fit many different network drivers on one floppy and the main reason to go cd rom...MUCH FASTER!. i think this is possilbe buy somehow emulating a floppy on to a cd rom. ive done this before with bios's and its worked great but ive never been able to do it with ghost.
any help or insight would be greatly valued :D
when you say you've done it with bios's... you mean you created an emulated flaoppy on cd rom you used to flash the bios rather than using the floppy?
if this is the case, you're saying using the same method hasn't worked with ghost?
