SX3031W now on EIZO website
IanM
Supports scaling of non native res to full screen with correct aspect ratio
Single link DVI with 1920x1200 HDCP is a seperate input from the Dual Link DVI input
Almost certainly S-PVA panel (see below) & will probably have very similar input lag to the 24" EIZOs
Main product page: http://www.eizo.com/products/lcd/sx3031w/index.asp
Spec sheet: http://www.eizo.com/products/lcd/sx3031w/spec.asp
English press releases for SX3031W & CG301W: http://www.eizo.com/press/releases/index2.asp
UK price of SX3031W is estimated at £1500+VAT & availability Nov/Dec
EIZO Japan also have the CG301W on their product page: http://www.eizo.co.jp/products/ce/cg301w/index.html
Edit: These things are probably S-PVA given the way the table looks on this page:
http://translate.google.com/transla.../products/ce/index.html&num=30&hl=en&safe=off
Note the 'Angle of Visibility' row - the IPS displays have a bullet in this row, but the VA panels are blank (the pdf below the table tells you which of the CE series are IPS & VA, but the 30" isn't on the pdf yet)
there is also a PDF format press release with a 30" MX300W (medical display series, so probably not so interesting for this forum)
As far as I can tell, the CG301W will be the first 30" Ips with brightness consistence adjustment across the panel. It will also feature multiple inputs, split screen and pivot.
Let's hope it will be under 100$ ;)
-tarc
