SWTX 19" rack case and cooling
nolem
Hi,
A while ago I got some used G34 AMD CPUs and got myself a H8QGL-iF-O motherboard: http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8QGL-iF.cfm
The purpose of the machine is to do distributed computing and I will likely put some GPUs on it as well.
I have a 19" rack which I could put it in but it seems that the Supermicro cases that supports SWTX is either small (2U) or very expensive. I could go for a regular case as well if that would be cheeper but 19" case which isn't 3x as expensive as the mb would be nice :)
Also I'm thinking of adding liquid cooling to it to keep the noise level down a bit.I wonder if anyone has any suggestions on both the case and/or the cooling options you have went with.
Cheers!
You are not trained in the ways of a dremel and duct tape :D
This was worse. The redundant power supplies plug into a backplane which has all the plugs (24-pin, 8-pin, etc). Part of this backplane was too big for newer motherboards (4P 2011) but worked with other motherboards. I think I ended up using this case with the 4P Opteron SWTX, but I had originally tried the 4P Intel and it wouldn't fit. There's no way to dremel the power supply backplane and maintain a working system. :p
The HAF932 case seems to be a classic.
I found this usefull : http://www.overclockers.com/forums/showthread.php/701036-Project-Quadteron
Edit : I just had a little trouble with a longer PSU (an AX1200) interfering with an internal USB port that I had to trim a bit.
I also found that the 8 small noctuas + the small northbridge fan are rather noisy. I guess something without a northbridge fan and with less and bigger CPU fans might be quieter. Maybe something, like this : http://hardforum.com/showthread.php?t=1676632
