Switftech H220 in a corsair 250D
wizang
I'm having trouble finding definitive proof that a stock swiftech h220 will fit in a corsair 250D. NCIX has the 220's for $100 right now which is cheaper/better than an h100i. Anyone done this yet?
if you can fit a 240 rad in there, then i dont see why you cant fit the h220?
I believe thickness is the limiting factor, the h220 is slightly thicker than the h100i.
If you want to measure it yourself, stack two fans where the rad will go. Thats 50mm of space. The h220 is 29mm so you'd need another 4mm clearance from the board. Each fan is 25mm if you are using normal ones so total clearance you need is 54mm
Doesn't the H220 have a housing at the bottom of the assembly?
That may make the whole thing a lot longer.;)
You'll need exact measurements.
