Currently my system is as follows:
Motherboard: Gigabyte 965P-DS3 rev 3.3
CPU: Intel Core 2 Duo 6600
Heatsink:Thermalright HR-01
RAM: Corsair Twin 2x 2048-6400C4
Hard Drives: Two Seagate 7200.10 500 GB
DVD Drives: Samsung 18x DVD RW and Pioneer 18x DVD RW
Graphics Card: EVGA GeForce 8800 GTS
Sound Card: X-Fi XtremeGamer 7.1
Power Supply: Corsair CMPSU-620HX
Case: Antec Performance One 180B
For the past ten months I've had no issues with it but yesterday when I tried starting up it would continually reset after 5 seconds (after the fans connected to the power supply go on but just as the fan connected to the motherboard is about to turn on).
I'm first going to see if it'll work with different RAM and then power supply and if the problem persists then cleaning the cpu and reapplying the thermal paste. If none of these work I'm guessing that it has something to do with the motherboard.
Since I bought it a few months before I built the system the motherboard is already past warranty. At this point would it be a good idea to buy the same motherboard type or something similar (like an ASUS P5B), which seem to be hard to find at this point, or should I go for a newer motherboard? Also, will there be any issues with the operating system or any devices because of the change?
Thank you for your help!
