this is how easy it is to upgrade my HP DV7 4060us. After working on a few of these DV7's, I wouldn't recommend them, seems to have issues with heat damaging the chips on the motherboards causing no video or no boot. this machine was a parts donor for a machine I was fixing for a friend, we ended up not using any parts from it and he bought the rest of the items to finish it off and gave it to me as payment for working on the other 2 DV7's. I paid for the SSD and Ram upgrade myself though.
I installed Diablo 3 on it just to see if it would work and it plays surprisingly well, was pretty impressed.
I was looking around, and noticed that there are different kinds of ddr3 memory, and that they are not interchangable. I got this from the internet.
" DDR3-800 memory is the slowest type of DDR3 RAM. It has a 100 megahertz memory clock and a 10 nanosecond cycle time, with a 400 MHz I/O bus clock. DDR3 is also sometimes called PC3-6400 for its peak transfer rate of 6,400MB per second. DDR3-800 differs from DDR2-800 only in the speed of its memory clock -- 100 MHz vs. 200 MHz -- and its cycle time -- 10 nanoseconds vs. 5 nanoseconds. As of 2011, this memory type is largely obsolete.
DDR3-1066
DDR3-1066, or PC3-8500, offers a 133 MHz memory clock and 7 1/2-second cycle time, with a 533 MHz I/O bus clock. This memory actually has a peak transfer rate of 8,533MB per second, rather than the 8,500 implied by its common name. This is due to the convention of rounding down decimals when figuring the data rate of memory.
DDR3-1333
DDR3-1333 memory offers a 166 MHz memory clock and a cycle time of only 6 nanoseconds. The I/O bus clock runs at 667 MHz. DDR 1333 is also known as PC3-10600, and may be sold this way by computer retailers, but actually provides a peak transfer rate of 10,667MB per second. Some manufacturers round this memory's capacity differently and may call it PC3-10666 or PC3-10700. However, these differences in marketing don't indicate any difference in memory speed or efficiency.
DDR3-1600
DDR3-1600 RAM offers 1,600 million data transfers per second and a peak transfer rate of 12,800MB per second. It has a 200 MHz memory clock and a 5 nanosecond cycle time, with a 933 MHz I/O bus clock. As of 2011, this RAM is the highest readily-available speed of DDR3, though faster RAM can be purchased through some specialty retailers.
DDR3-1800
Also called PC3-14400 and DDR3-1866, DDR3-1800 memory has a memory clock speed of 233 MHz and a cycle time just over 4 nanoseconds. Its I/O bus clock is 933 MHz. This memory offers 14,933MB per second as its peak transfer rate. Due to rounding differences, this RAM may also be called PC3-14900."
Now one of my laptops was made in 2012, while the other was made in 2013, so the age difference is not big. So maybe during that time period, the memory types were the same, but I haven't confirmed it yet.
Something else I would like to know is... Generally speaking, what types of tools are needed to change parts (hard drive, memory) on a laptop? For example, on the desktop, you would need only a philips screw driver. Is it the same for a laptop?
