Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
[H]ard|DCer of the Month - February 2007/January 2
Delete the GUI exe and install the console.exe.
Make a shortcut and add the -configonly switch.
Start from shortcut and config it.
If it works right it should show you your username, ect, etc from the last install you did.
Restart in required mode with the switches -forceasm & -advmethods as needed.
Hopefully that should work.
Better still just wait untill you finish a Work Unit and are on the first couple of frames of a new one.
That way if it goes wrong you dont loose that much work.
