TwistedMetalGear
- Jun 19, 2005
Hey, I just bought a Thermaltake Eureka tower to replace my Lian Li V1100+B tower, because I have an A8N32-SLI motherboard with a heat pipe and being inverted makes the chipset a little too warm for comfort with the summer coming up, so I'm in the process of switching out internals now.
Questions:
1) I mounted the hard drives backwards for better cable management. Doing so made the sata cables on back of the HD get bent at pretty extreme angles. I mean they're still curved don't get me wrong, it's not like bending a piece of paper where you get a perfect sharp right angle, it's just that they're bent a lot more than they should be. Now I don't know how sata cables work, will being bent like this affect anything?
2) I have a Vantec multiple fan speed controller that I would like to use to control the CPU fan(huge VERY HIGH RPM panaflo)... The manual states not to use it on the CPU fan. I'm guessing that this is just because some mobos won't even post without the CPU fan plugged into the corresponding connector on the motherboard. Is there any other dangers of hooking it up to the fan speed controller rather than the motherboard? And also, will the A8N32-SLI post without a fan hooked up to the CPU_FAN connector? I'm thinking it will because the Panaflo isn't really a CPU fan as it is, and I get CPU fan errors at post even with the fan connected to the proper connector but I think that's because it doesn't have the third connector that CPU fans do. (speed sensor connector?)
I appreciate any help guys. Thanks!
Questions:
