Switched cases, can't boot
CHAoS_NiNJA
Sorry if this is in the wrong forum, I'm in a bit of a hurry and I'd really like to get my stuff up and running again.
I recently got a Silverstone TJ06 for Christmas. Yesterday I switched all my stuff out of my old case into my new one. I obviously did all the wiring correctly, got all my stuff hooked up and screwed down, and when I go to fire my machine up... "Error loading operating system".
WTF. How can switching cases hurt my OS? The only thing I can think of is I wracked my HDD around to much installing it (because it uses bracets to hold the HDDs instead of screws). If this is the case, am I simply SOL? I don't hear any grinding in the HDD, it just spins up like usual...but it doesn't spin up for the OS.
Does anyone have any idea what I can do? I would have reinstalled windows already...but I somehow got caught without a copy of XP anywhere near me.
Help?
(Once again, sorry if this is in the wrong place. Please move it where it needs to be.)
take the hd out of the rack, and see if it boots like that.
if it does, then the rack, or something is shorting it.
I checked for shorts and removed the HDD from the rack...nothing. Still no boot and no extra HDD activity. Hell, I tried to load up Ubuntu live CD and that wouldn't even boot...
Pull rig out of the case and try again.
Last time I had this problem, I had an extra brass standoff in there.
Not to sound like a dick, but are you sure?
That really sounds like a cable/wiring issue to me.
You might have forgotten to plug in the molex / SATA power cable, or you have the boot order in your BIOS set incorrectly. That's pretty much the only thing I can think of off-hand.
What happened when you tried the Ubuntu Live CD? Did it start to boot and then fail? Does Windows start to load or does it give you that error message before Windows even starts to load?
Do you live in a dry climate? Winter is usually a dry time of year. Did you take proper precautions for static discharge when you switched systems?
mdameron: will do tomorrow.
digital_exhaust: I've been up and down the wiring job about 40 times, I don't see anything out of place.
Also, what kind of "wiring issue" would cause that?
B. W. : neg, been over that.
metallicafan: Ubuntu loads up to where I would usually get a GUI, but then tells me it cannot complete booting, and ask me if I would like to see an error log. Before I can click "Yes", the command line comes up over it, sloppily overlapping the pervious screen. It starts on one side of the screen, but if I hit enter, it goes sideways, like this:
Actually, no...I was not able to protect against static, as the area I had to work with was...sloppy, at best. And yeah...there was carpet.
Another thing: I just formatted my HDD completely. It did *nothing*. After I formatted and rebooted, i waiting for the "Press to boot from CD to pass"...and the split second it passed, the message of doom appears. "Error loading operating system."
Figures the biggest LAN in MI is gonna be in a few days...
Unfortunately, it looks like the hard drive may be shot. Transferring from one case to another probably damaged it somehow. Sorry man :(
Don't give up hope just yet, though. Sleep on it then play around with it some more.
Well that shoots the shit out of the shorting out theory.
You've got bad hardware somewhere I reckon...
are you able to try a few repair commands? try these from the recovery console in xp:
fixboot
fixmbr
go nuts and see what happens.
Ok, well, I fixed it. Know what it was?
The IDE channels.
Its makes no sense to me (well it kinda does, but still), but I ended up switching my IDE channels and....bam. it boots. wtf. I feel stupid for not trying it earlier.
Thanks everyone for the help.
I was thinking that your HDD was sata...oh well, glad to see you got it working :)
