switch to water cool
moocow0463
so im looking to upgrade my GPU to a GTX 970 and i like the idea of water cooling, to cut down on noise and of course increase performance but i have absolutely no idea how to go about this.
what blocks would i need for a basic water cooling setup, VGA, chipset etc, would i need case fans to cool the ram? pump fittings hoses etc? looking for cheap but reliable so if it comes at a cost that is fine but if possible like to the budget low as possible
system
cooler master HAF 932 case PSU currently mounted in the bottom of the case and it has a spot for a reservoir in the top that i would take advantage of is possible
i7 3820
asus x79 deluxe
GTX 970 gpu (in the future)
4 sticks of ripjaw ram
