Hello,
I just recieved a linksys 8port switch SD208 and I have a few problems,
first I can t seem to get the uplink to work with my router. It s the alcatel speed touch pro. I can t detect it on the network, however if I plug it in my 10mbps hub and then connect the hub to the switch it works, has anybody got an idea how to fix that?
And on another note, the switch makes a lot of "power noise", is it because their switches are just crappy or should I return it?
Best regards,
JJ
Best regards,
JJ
