Swifttech h20-80 in qpack
Lolento
I'm looking into using this setup in my qpack.
I know there must be some of you who are using the same kit. I wondering if you can post some pictures on the setup.
Also, I would like to know how you connected the GPU block if you have the GPU block? Did you connect serially upstream or down stream from the CPU? Or does that matter at all?
Thanks,
i did some research on the 120 rads....with that setup I have to place the rad on the outside of the case right?
i really want to fit everything inside the case.
You can fit a 120 inside (I've done it), but you're going to do alot of hacking. 80mm rad isn't going to cut it. Hell, 120mm rad barely cuts it. My suggestion if you want everything internal is to use the Evercool WC-202 kit from Performance-PC's and use an aftermarket GPU block with it.
well, i'm using up the 2 5" bays on my qpack for a dvd burner and a ide mobile rack.
btw, does the evercool kit perform better than the Swiftech h2o 80?
I bet the Evercool will cool better than the 80mm rad. I bet air cooling will cool better than the 80mm rad.
