cnick79 said:I plan on using 3/8" ID tubing, do I need any special adapters to use the swiftech MCW50 block?
rtierney said:The fittings are 1/2" OD. You'll need tubing that is exactly 1/2" OD
If you use Tygon 3/8" ID, the OD is still 5/8", so you'll need an adapter like what I did with mine.
Check my thread for a picture of what I mean.
