Swiftech MCW6002 - using stepped version for A64?
Silmatharien
I'm upgrading to A64 in the immediate future and just found out there are two versions of this waterblock. I have the stepped version to clear the cambox on the CPU socket for skt 462 CPUs. Has anyone tried using the stepped version for A64 processors? I don't really see that it would be a huge issue since the die is just in the centre of the processor anyway.
Thoughts on this?
Depending on how the nipples are oriented on the stepped 6002 it might line up the step with the cam-box on the 939 socket which would be beneficial if you should decide to remove the IHS on your proc.
