They are both high performance high flow blocks of very similar designs, I dont think there is a big enough performance difference between them to say one is better than the other IMO.
Had an mcw50 for about 3 years... never had a problem with it. The 55 looks to have quite a few improvements. Never used the maze4 so don't know about that one. One other thing to keep in mind, the maze4 has barbed fittings and the mcw55 has the quick connect fittings so if your using 1/2 id tubing you'll need to order the adapters as well.
The MCW50's major flaw was the alluminium body now replaced with derlin, swiftech know exactly what their doing. The other thing I can see is that the MCW55 looks like it has more surface area and is overall slimmer, then again the maze 4 has a thicker copper base and overall abit bigger?
They both rock a$$... what do you have for your cpu block? If it's swiftech, why not keep your hole system swiftech. Vice versa if it's DD. Better yet, get both blocks and mod them in a way to combine them both together... sweet!! best of both worlds.. see you in the worklog area on that one!
