I don't think it does (many places don't, but do offer the option for purchasing the fittings with the item).
I would, however, go to Sidewinder Computers and get it there. The MCR320-QP is a little cheaper and the shipping isn't as high. You also save a few cents on the fittings, as opposed to purchasing them separate. Link
Edit: I personally like EK High Flow barbs. They are easy to screw in and are less restrictive when I have to fit my tubing over them.
If I remember right, it does come with the plastic barbs for it.
If it does, then they'll be fine for the time being. I personally prefer metal fittings because they last a lot longer and don't leak as easily. Not to mention they're a lot stronger.![]()
Sweet. Let us know how it works out for ya.
Yeah my mcr320 didn't come w/ fittings...had to use the ones from my mcr220. How do the metal fittings work? Are there fittings that you can disconnected and have the liquid be locked in (if that makes sense). Something a bit more elegant anyway.
