Swiftech MCP655 Pump dimensions
DanSan
I cant for the life of me figure out the dimensions on this pump being that swiftechs website photos are completely useless to me. So i can make this simple, does anyone know specifically the dimensions of the following: How long is from point 1 (being the front most part of the pump) to point 2 (being the very back end of the pump)
Because what i plan on doing if it can fit, put the radiator and pump inside the empty drive bays of my thermaltake armor this way i dont see anything
3.74" 95mm ,its actually about 3.5 " to your points ,the mounting bracket sticks about a 1/4" or so past the motor
If you scroll down on the Swiftech product page they have a diagram right there, it's 90mm long.
ok thanks, and yes theelectic i saw that but i was unsure about the distance after the pump. Which i guess is only 5mm and is the mounting bracket homer was talking about
