Swiftech MCP600
OtakarJr
I've got a quick question:
I've just ordered the Swiftech MCP600 water pump. Do I need any fittings to connect it to 1/2" OD tubing? (3/8" ID). It looks like the pump has 1/2" ID inlet and outlet.
Anyone know for sure?
The pump has indeed 1/2id tubing inlet/outlet.
Maybe you will be able to extend your tubing on the fitting but I doubt. You wiull need some sort of adpater with a small piece of 1/2id tubing.
Like this 1/2id to 3/8id : here
what you will do his :
Pump outlet 1/2id->tubing 1" 1/2id->fitting 1/2 to 3/8-> 3/8id tubing
