Swiftech MCP600 Pump orientation
DaLurker
I was wondering if there was any particular orientation the pump needs to be in to operate correctly? i was thinking of rotating it 90 degrees so the inlet is at the top, and the outlet it out the side.
Actually the best orientation is with the inlet facing straight up and plumbed straight into a reservoir.
I actually asked this question of Swiftech and thay said it would work in any orientation and anywhere in the loop as long as it was below any reservoir in the system.
BigTaf said:
I emailed swiftech as well and got the same response
Great! I actually emailed them as well, but since it's a Sunday, didn't think they'd give me a reply.
Glad to know, now I can go and buy myself one. Heard good things about this pump. Hope it helps decrease my temps!
