Swiftech MCP600 mounting question
laozx
Hello, I was wondering if it matters which way you can mount the pump. Standard mounting looks like the intake valve is horizontal, while the exhaust valve is vertical. I want to mount the pump on it's side, so that the intake valve is vertical and the exhaust valve is horizontal. Will this be okay to do?
Thanks
