Swiftech MCP355 Questions?
OofC_S7v7N
I am wondering how good this pump would perform with two raidators waterblock, northbridge block and possibly two graphics blocks. I heard it performs good but havent heard how good with alot of hardware?
Will it power through it all? Yes!
Will it hurt your temperatures a bit by not going to a stronger pump? Probably.
By how much? Very little ;)
It'll be fine.
The mcp355 would work a lot better if you either get petra's top or alphacools modified tops to improve the flow.
If you're not getting at the very least, 1GPM, then upgrade as you'll see MUCH better improvement in temps. If you're already above 1GM, then you'll see diminishing returns but the gains are there.
well what i want to do is have it in this order, pump1 out to radiator1 then to cpu then to radiator2, then to north bridge block, then to gpu, then to pump2 to reservoir then to pump1
1 MCP350 was fine on my old setup, I only had a decrease of 2C when I added a 2nd MCP350 to the line. Just remember to get either Petra's or Alphacools modified top for your pump.
My old system = MCP350 with Petras top > MCR220 > Apogee GT > DD 680i > 2nd MCR220 > 8800 GTX > Alphacool SB > Microres
