Swiftech mcp350 or Alphacool ap700?
Just wanted some opinions please, I have a swiftech mcp350 in which I am gonna go with the alphacool laing ddc top or should I go with an alphacool ap700. My loop will be:
BIP 120.3
AC Cuplex XT
AC Aquagrati X1800/x1900
AC Aquatube
AC 6mmx 8mm tubing
AC plug and cool fittings
I heard the laing ddc pumps are loud with the aquatube but how loud? I hope I won't hear it as I am using 3 low panaflow 120mm fans for the rad. I have the alphacool ap700 but would like to order the alphacool top for my swifty mcp350. So what do you guys think?
i have a laing DCC plus with alphacool res and top and it is not loud at all.... you need to make sure no air is in your system, which can take a while, Air makes it loud. No air is quite....
