Swiftech MCP300 pump mod questions
eXacto
I want to mod my pump because of the leak issues that commonly occur with the alu. intake piece and because I need a reservoir in my system. I have seen on many pumps the res directly attatched to the pump, which works the best because it provides the most positive pressure.
The problem is that I have never seen one on an MCP300 and now that I've been trying to find something that will fit, I think I realize why. If you look at the picture below you can see that there is almost no room around the outside of the intake valve to attach any piece of PVC. I can't reall think of anything else or any other way to directly mount a res onto the pump (after taking the blue intake off). Does anyone have any bright ideas or even links to mods that have already been done?
(yes the pic is taken from ambmb.com but I hosted it on my space)
Right, not in the reservoir. I want the res attached to the pump where the intake hole is, which is where the larger blue piece is in the pic.
