Something about this pump's speed control just screams "shitty build quality" as though I'm dealing with a $20 cheap Chinese desk fan.
Contrary to the picture (http://www.sidewindercomputers.com/swmc12vdcpu.html), my pump has a sticker with some numbers on it, not embossed numbers.
Anyway, I first tried turning the knob with a screwdriver before I even installed the pump, and it gave some force before it clicked and then just kept spinning rather loosely. Depending on how much you turn it and in which direction, you can feel some resistance, but there is absolutely no rhyme or reason to it. It's not like there's a distinct click from one number to another - the thing just goes in circles. I have no idea what speed setting it's at.
With the unit on (in a running loop), I tried to listen to it and feel it vibrate while trying to adjust the speed, but there's really no way for me to tell from sound or vibration what's going on. Maybe the speed is just constant and isn't even changing?
Not that I have the inclination or energy to undo my whole setup just to send this shit back...it works and it's quiet, at least.
