Swiftech Laing D5 Vario MCP655 - Pump behaviour
luigidon
Hi there
Anyone got one of the above? Can you tell me whether the pump operates in an on/off rhythm ? I was expecting the pump to be constant. If I hold it I can feel that it pumps for a couple of seconds then off then on etc....
Also, any recommendations on a flow setting as this pump has 5 - I cant really see if water is being pumped round the loop and with the 'unusual' pump action I am suspicious
Is this normal ?
cheers
no, most definitely not. My MCP655 pumps continuously (like all pumps should), so I would check your connections and otherwise RMA it.
cheers buddy. wating on a new PSU so I'll check it then otherwise I'll RMA it as you suggest.
Before doing a RMA, check if the molex connector is correct. A bad contact could cause this as well...
