Thinking of upgrading my Cryorig H7 to a 240mm AIO. I have a Thermaltake Core V1, which officially supports only 140mm coolers. Then again, officially, I can't fit the H7 in there either.
After studying just about everything out there, it looks like the Swiftech H220 X series (and only the H220 X) will fit in the V1, thanks to Swiftech putting the reservoir on the back of the rad instead of the top/bottom. Any other 240mm rad would require cutting holes in the exterior panels (V1 is ~265mm from top panel to bottom). Doable, but undesirable.
Only issue is that reviews seem to be thin on this series. It looks like the included PWM splitter is over complicated and crap, but I was planning on getting a basic PWM Y-splitter cord and running the fans off the Mobo header anyway. Maybe wire the LED connector into my existing 5050LED strip (or just leave it off, because how many LEDs do you need in a case?).
Anyone have any experience with this series? Comments?
