Swiftech H220 X2 Vertical Mounting?
Vader
I'm updating my pc with the new NZXT S340 Elite case when it comes out and also my watercooling. I really don't have the time to go baller on water, so I figure the next best thing would be to replace my bland Corsair H100i with something a bit more fun and i'm lookin at the Swiftech H220 X2 Prestige. The problem is that I won't be able to mount this horizontally on top but only vertically in the front of the case.
I have not seen these mounted vertically so i'm reaching out to you experts out there to see if they can be mounted that way. I know i'm gonna have to replace the tubing with longer tubes, I believe since the pump and reservoir will be at the bottom front of the case so I have to plan for that as well.
Any input would be great and no..i'm not going all out water so that's not an option. Worst case, I go with an NZXT Kraken X61 which I know will work.
