Ok, so a while back, my Swiftech H220 pump died. I cannot find any paperwork on it (I must have bought it 3rd party), so Swiftech can't/won't replace it under warranty. For the time being, I have a H50 on my rig. I'm curious as to what some options would be. Here is what I have:
1) Buy a Swiftech MCP50X pump, and disassemble/replace pump on H220 CPU block.
2) But a completely different pump (and possibly CPU block?) and just insert it in-line with the rest of the unit.
3) Replace with something else like a H100 (newegg has refurbs going for $65 currently).
4) Keep using the H50.
I am running a i7 2600k, not overclocked (no need to). The downside of #1 is that I void the warranty on the pump.
Let me say that while I have these, I have not gotten into water cooling. In a way, it kind of freaks me out that a leak will develop and I'll have to replace my whole computer. Also, there is the maintenance on the loop, hence why I like the maintenance-free AIO coolers.
What would you guys recommend? If I end up going with another AIO rather than try to use the parts of the H220, is the H220 worth anything selling it with a broken pump? Thanks in advance.
