I'm hoping that someone out there with this kit or more experience water cooling can help me out with a problem. I've already done a search on these forums and found the issue a few times but no solution.
I've got the kit installed (H20-120 Premium) and have probably run it for about 5-7 hours now to make sure there are no leaks. This kit uses a 5.25 reservoir/pump setup. Well my problem is that it makes a constant "splashing and slushing sound". I've topped off the fluid mixture as far as it'll go, but if I look at the mounted reservoir from below with a flash light i still can see tiny air bubbles and about an 1/8 of an inch that isn't filled with water.
Needless to say the noise is annoying and i can't figure out any way to fill it the last 1/8 of an inch or find any way to stop the noise.
Any tips would be GREATLY appreciated. This is frustrating for my first watercooling experiment!
Thanks!
Thanks!
