swiftech fill and bleed kit
BigTaf
Any good?
just dont see much about it around the forums, which is odd because it seems to overcome alot of the problems associated with resevoirs
From what I understand from the Swiftech web site, the F&B kit has been replaced by the new 5 1/4 bay rez on all new kits.
the new one looks pretty easy to use and if its that simple to bleed how can you go wrong
Filling and bleeding the first time isn't too hard.... but the second time's a killer. I could never get all of the liquid out of my loop, so when i went to fill it trapped a bunch of air, enough so that the pump wouldn't work correctly. I ended up getting a bay res instead, it worked a whole lot better, no bleeding involved. The one I have has a few issues, but with that new one Swiftech put out it should do a real fine job, I'm thinking of buying one myself. Plus with a res mounted high in the system, you can use gravity to fill your loop, rather than having to suck at it and possibly end up with a mouth full of antifreeze (Like me, haha).
