Bio-Hazard said:The Swifty instructions give you some very very good ideas on how to run your tubing and order of components. Follow them and you'll have zero problems...................![]()
infiniti029 said:Time for a thread hijack...
I just bought the Swiftech H20-120 kit. Does it matter which drive bay I put the reservior in (top, or bottom)? With the kit I have the the MCP350 pump sits in the drive bay with the res and is directly connected to it also.
Not just for aesthetics.alphakry said:d. shortest routes are usually best... for aesthetics, i have pretty long routes. But shortest tends to be the way to go!
i'll work on it.i run my radiator outlet to the CPU inlet and have great success this way, as do many others. The choice is yours.
hero123 said:hello again, just wanted to ask, how i fit the radiator into a 120mm fan slot thingy, i have a antec p180, and will cut the grill off to hang the radiator, but not sure how to![]()
anyone got ideas?
