Bio-Hazard said:They are the same exact pump...................![]()
http://www.swiftnets.com/products/mcp655.asp
Considerably reduced audible operating noise: the high pitch frequency of the MCP650 is now eliminated thanks to a new chipset controller,
Head and flow characteristics have slightly improved in the midrange,
A potentiometer allows to adjust the pumps speed from 4800 rpm down to 1800 rpm. At 1800 rpm, the pump is virtually silent. This allows users to tune the pump performance/noise ratio to their particular preference.
D4RK1C3 said:So what your saying is its quieter and has an adjuster? Like i said, right?
both pumps have the adjuster. both pumps should have the same noise level.D4RK1C3 said:So what your saying is its quieter and has an adjuster? Like i said, right?
Erasmus354 said:The problem with submersibles and many of the higher powered pond pumps is that they weren't designed with efficiency in mind. Lots of them dump a lot of heat into the water, which lessens the performance of the entire loop. A "rebrand" with lower flow will often times produce better results because they dont put out as much heat.
This applies much more so to submersibles than other pumps.
go back and mod the 350.....ironically i bought a 655 thinking that it was going to be quiet compare to the 650, and 3 days later by mistake i recieved a 350.best mistake everluie said:I have a MCP655. I find it have a very high pitched noise. It makes me want to quit watercooling...I'm serious.
Maybe it's because my 1st pump was a MCP350...![]()
ryuji said:doesnt the 350 have issues with you needing to beat on it to get it to start my comp wouldnt even start if i had to do thati pulled the plug on my pump to put it on a testing psu to check to see how much stress it was putting on stuff, i watched 6800 temps just for the hell of it as i did it, temp went from 45 to 52C in under a second, but it was under load... the cpu went up way faster i bet but i didnt watch that but envision 1.55v prescott at 4 ghz and youd get the idea
DarkenReaper57 said:Hmmm...to look for a used D4 for cheap, go with a D5, or stick with my eheim 1250...
Decisions, decisions.
ryuji said:and iirc the d5 out performs it, would have to look up specs tho
Just checkinBio-Hazard said:More than a few times...................![]()
but it's always nice to see the link..................![]()
Russ said:def not a D4. I'd get a D5 in that situation though. Isn't the eheim an AC pump? And it's big. Yuck on both counts.
