Few bux more and you could get the 1600X. Scale closer to 4Ghz on the OC
I would say the 1700
I say the 1700 is the most bang for the buck. I see 8 core going to be more useful in future games now that core count is actually going up across the board. If that is your thing. If you plan to keep this system for awhile spring for the 1700. If it is a stop gap or something get the 1600.
Next year they may have a 1900X or something. I know they will have Raven Ridge APU with integrated graphics. The platform is suppose to be long lived. Zen + will be coming and that has to be faster.
Those are essentially air. You might not see the difference you hope for unless you get a top notch all in one.
Part of a true water loop cooling capacity is in the entire fabric of the system. Having a very large volume of water i.e. bigger radiator and a reservoir and large diameter tubing allows a mich larger thermal capacity. You see when all is flowing through the loop the temperature of the liquid stabilizes to a constant temp throughout the whole system even under heavy load. External pumps will lend a much higher velocity further diminishing a hot and cold side to the loop. That's why it's always been argued that a true loop has very stable temperature state under varyingload states.
When you sample coolant temp on a true loop you will see very slight coolant temp increase under heavy loads with minimal decrease when going back to a resting state.
All in one's lack the necessary volume of liquid and essential velocity to allow a stable thermal balance throughout the system.
Sure all in one's will lower temps of cpus all day long but they cant remain cool under hour long full load scenarios unless they are oversized for your Cpus total thermal output.
So get the biggest and best AIO you can find or put a true loop in if you want steady and consistent actual cooling performance.
My 1700x idles at 25c when AC is on and under full load never surpasses 55c. When I had an AIO on it for a temporary solution when the chip first came out my temps were 35 idle and full load for an hour was getting over 65 to 75c. Huge difference between all in one's (convenient compromises) or custom loops (expensive and best).
If your gaming only get the non x quad or 6 core. Save your monies for better things like a 1080 or a Vega when they hit the shelves.
Wrong on all counts. Mass has no influence on cooling. Speed does, but because of turbulence.
Is that so? Care to explain? Im befuddled that all the laws and observations of physics do not apply.
That's a bold statement that requires explanation. "Wrong on all counts".
