Sweet New LED's
Status
Not open for further replies.
[Sarcasm]Nice!
I think ill buy some. :D[/Sarcasm]
I have seen these type of LEDs for years and I still wonder how they are powered. Is the long two antenaes their plug?
ha ha ha...
that was a joke right?
lmao "they go straight into a socket on the wall"
If he wants you to die, then he's serious. :D
Everfalling said:
ha ha ha...
Sadly, no it isn't. They are so cheap that the last time I bought fans I thought I'd just buy them to see how the hell they work but I never did. If there are wires and a power inverter, it surely is never shown.
electricity goes in one wire, passes through the diode to make light, comes out the other side. not sure what you're confused about here.
Hmm... I guess 3mm is smaller? I'd like to see one in action...
But exactly what do they plug into? Do you have to strip two wires and wrap them around the metal posts?
Your computer already has LEDs in it for the drive activity and power indicators.
To replace an LED with a different color, simply unplug the connector from the motherboard, cut off the old LED, connect the new LED, and replace it. You don't need to worry about polarity... if it doesn't light up, flip the connector around.
The LEDs they are selling are nothing more than standard T1 LEDs. Nothing new, they've been around for YEARS and are commonly used in everything from toasters to TVs. Hell, even your walkman probably has one in it. They arent any special color or brightness or anything. Just standard T1 LEDs.
BTW, for the LED noobs:
T1 = 3mm
T1 3/4 = 5mm
that, or solder the two leads to a board. gotta know about circuitry for that though. but yeah, however you can get power to it. i think it just depends on the voltage
Yes, but I'm afraid they don't have metal posts in the trailer park.
T1 = 3mm
T1 3/4 = 5mm
Thank you. Very informative.
Status
