archangel0585
- Nov 4, 2003
Ok guys I love the fact youre all giving me these upbeat responses and cheering me on. But I will say 1. I will bench mark at stock stats. 2. This is not the first comp Ive worked on or built
simply the first for me. I snapped and decided I wanted to do it my way. Not go
ohh ho hum
but just go
.you know what
damn it its my way
.. this time for me.
My friend whos helping me build it is pretty sure about the specs we can get (side note, hes the mod for the over clocking and cooling forum on [H]). So Im pretty sure I can get it where I want it. Ill post some specs once I get it all together and running (hopefully
). But Im pretty positive, thanks for the support guys. I cant wait t see what the max 3 can do though because I wont lie
I havent worked with one before and I nearly went to an is7 or base ic7 for the cost issue
but hey, I wanted to play with it. but yeah..Ill get all of you bench marks when its all said and done. Question though, do any of you use a max3?? Well hopefully some of you do
I should be useing one by mid next week
I was also wondering what some of you might of gotten as a speed for a 2.8c...call me curiose. well until then
