So a friend of mine wanted to swap out his 320gb drive for a larger 500gb drive.
I figure.. simple... pop open acronis or ghost - clone the drive, yada yada yada easy as pie.
FAIL!
Ok here is the dilemma - when I pop open acronis I see this.
Disk 1
Ext3: 167.xx GB
Swap File: 20mb
Linux: (forgot what went here, something like 200mb)
Linux Pri 0x83 No Partition 297gb
Disk2 (old drive)
Ext3: 19.xx MB
Swap File: 20mb
I need to expand Extended 3 onto the primary linux partition. However, you're dealing with primary/extended partitions.
I need to leave the 20mb of data on extended3. I figure I'd have to delete the partition, recreate two more partitions (a 50mb ext3, and a primary non-formatted partition with 167gb). I would then clone the data from the old back onto ext3, and then grow the 167gb back onto the primary partition. Just wonder if this is the way I should go about doing this.. or is there an easier way?
I probably confused the crap out of everyone....
Any help would be appreciated.
FAIL!
Disk 1
Ext3: 167.xx GB
Swap File: 20mb
Disk2 (old drive)
Ext3: 19.xx MB
Swap File: 20mb
