Swapping Mobos
guito13
Midnight Mulcher
Ok, heres the deal:
I just got a newer motherboard / processor (Gigabyte K8N Pro / Athlon 64 3200+ (Newcastle socket 754) ) and want to put that into my gaming rig. It currently has the A7N8X deluxe / 2500+ Mobile Barton combo in it. Idealy I would like to keep everything else the same (9700pro, drives, ect) however I am unsure what steps would be necessary to swap the board / cpu only. I am assuming that I would need to remove any motherboard drivers before swapping out, swap, and then install the new drivers (Yes, I know this has a 99.99% chance of requiring my XP to be reactivated). Does this sound like the proper route / am I missing anything?
Alternatively, I could put the board / CPU in a new box, use the ram and card from the current system with a spare 80gb drive I have laying around and just put older ram / card in the current machine. This would require me to purchase another copy of XP which i really dont want to do but will if it is a lot less hassle.
Cliffs: Better to swap board/cpu or just build *new* complete system and purchase 2nd copy of XP?
Thanks!
You can just take out the old mobo and mother board and put the new ones in. Then install drivers. To reactivate just cal windows and say you reformated and lost your product key they should give you one.
Personally I would never feel comfortable making such a huge system change w/o doing a complete backup/format/reinstall. But maybe that's just me.
Thank you for the replies.
This is mainly my gaming machine. I dont have much on there that i deem critical data. I keep all of that stuff on my raid 5 box. That being said, I am not concerend about data loss.
With regard to telling M$ that i reformatted...why lie? I am still only using the OS on one machine but it was upgraded. I don't think that would require me to purchase another copy of XP.
i did the same thing. swapped out my Abit KT-7/ 1.0 Duron CPU w 768mb of PC-133 Memory and put in my rig a MSI Delta2 /2500+ AMD w 512mb of 3200 DDR 400 Corsair memory. when i got another stick of memory,the old re-active windows popped up. called them up and told them i added new memory and half-hour later,i was playing Far Cry.
had to take out my PSU and my CD-rom and DVD drive to get the old board out. i pretty much backed up half my stuff on 4 DVD's.
In my experience, Microsoft is pretty understanding of system changes, but you do have to call them up (PITA) instead of just being able to do it online or something like that.
Essentially, you are using the same unified driver for Nforce2 and Nforce3 and keeping everything else the same. You might not even have to repair install WinXP to get it to work.
Well, thanks again for all the info. I am backing up my MP3's and such right now. I will probably try to remove any of the mobo drivers that I can find before swapping, put the xp cd in the drive, swap, and boot up and repair if necessary.
If there is any last min advice please let me know. Ill probably start in a half hour...ill update with my results from my laptop.
Wish me luck!
It's a funny thing, a few years ago I changed from AMD to Intel, kept the same case and disk drives.
When I booted XP it just "found new hardware" and never missed a lick.
This week I changed cases and removed 1GB RAM and used a new floppy drive, and I had to call Microsoft for authorization, may they eat my shorts.
Update: All went well...i just pulled the drivers...swapped (Spent some time on wire management)....installed new drivers....reactivated windows via. the internet....board is teh win (way better than the 2500+ mobile)
