Swapped Bartons, YAY OCing better now
cgrant26
Well, I got a hold of another Barton 2500+ This one is a week 42 (other one was a week 38) and swapped it into my system. Before, Prime would fail after 20 min - 2 hours at 208 FSB & 1.75V. Now running at 210 FSB & 1.65V for a warmup and Prime has been running rock solid for the past 4 1/2 hours. Gonna leave it run overnight and tomorrow we'll see how far this mofo will go. :D
NF7-S Rev2
512mb GEIL Ultra Platinum PC3500 CL2 2-3-3-6
Radeon 9800 Pro
LRWW CPU block
DD Maze4 GPU
Thermalright NB-1C northbridge cooler
Water chilled to constant 17*C
Sweet, now running stable at 2.4 gigs, 220 mhz FSB
Prime failed once after 2 hours, but made it through two 4 hour runs after that. Memtest ran 1200% no errors.
congrats :D
if you really wanted to try your luck with OCing bartons, perhaps you should give the mobiles a try?
ST|FFY said:
congrats :D
I actually deleted something about going with a mobile before I posted that last update. A mobile 2400 or 2600 is definately in the works once I finish with my car.
