swapable hard drive enclosures
metallicafan
[H]ard|DCer of the Month - May 2010
Where I work we frequently need to take old hard drives and "clean/overwrite" them before we get rid of them. Is there a hard drive enclosure that someone could reccomend using USB2.0 that is very easy to swap drives in and out of? Or does anyone have a better solution than mounting the internal drive in a case every time? I'm not worrying much about the writes taking longer over USB than in would as an internal drive, I just want an easy way to swap drives in and out. Any suggestions? Thanks.
I have a thing similar to this, and it works fine. Do you really need an enclosure, or just the usb->ide convertor?
