svideo output black and white
Ampsonic
Hello,
Using the svideo output on my nvidia 4200 ti, running Ubuntu 6.10 for mythtv. Using current nvidia drivers and nvtv to control the tv out. It works, but is black and white only. I'm out of things to try to get it to work, wondering if anyone has any ideas.
Thanks,
Nick
you need to change some output setting. I have no idea how this works on an nvidia video card but my DVD player will output s-video black and white unless you select the right settings.
Make sure the output video mode is NTSC and not PAL.
(Or vice versa if you live in a country where the TV standard is PAL)
Did you try another cable? If the chominance pin is busted, all you'll get is B&W.
You are, of course, screwed if the pin is broken on your card's connector.
The cable is good, worked perfectly on the tivo I had hooked up before. Also, when I am shutting down the computer, for a brief moment, color bars apear on the screen. So I know it's possible for it to output in color, there must be some settings I'm just not doing correctly. Wish me luck.
