Suspended HD, HD crash?
MrPatate
Hi,
I want to suspend my HD (like in the P150) but there's one thing I'm not sure about, i get how to make it, strong clothing elastic. But if the case is tilted on the front/back or on the sides(depending on how the HD are mounted) wont the HD slide and crash?
P.S. is there a place were i can get the actual mounts of the P150, they look strong and nice... And they fit in 3.5'' bay instead of other suspended solution that needs 5.25''...
Thanks
ok, thanks!
But if the case is tilted wont the drives slide from the straps and crash?
if you decide to use the bungee / rubberband technique, make sure you cross over the bands on the side of the HD.
then, insert screws or standoffs in the side or bottom of the HD's and you'll have something to stop it from sliding.
d'ah the screws.... mmm.. i feel like an idiot :D lol... anyway the case is Lian Li PC-V2000BplusII, with it's size i doubt i'll turn it upside down hehe
