Nazo
- Apr 2, 2002
I had an annoying problem that I thought it would be easier to simply reinstall and start over with a clean efficient setup rather than deal with the hard way. While I was at it, I could integrate SP3 to my nLite optimized copy of Windows XP Pro. Unfortunately, it seems to have created a new problem. I can only assume it must be related to some service I took out, but when I was creating the optimized setup I compared with the service setup I had on the system I was using at the time and could just swear that I have the same services set to the same thing (eg same manual/automatic/disable setup even.) If it is a service though, it's one I completely removed apparently because I tried enabling EVERY service that would stay on. No matter what I tried the result was the same. I've also tried installing some basic prerequisites for various programs. Eg the Visual Basic runtimes, the .NET framework, Java, and so on.
No matter what I try though, the result is the same. I double click "installsurun.exe," it shows the "loading" mouse cursor for about half of a second, and then nothing. No error messages, no programs running in the background (which would be pretty noticeable given how many times I've tried it total now -- I should have about 50 instances of it running if it were just stuck or something.) In fact, it won't even show up in the task manager (unless I try to run it a LOT of times very quickly, then it might appear for less than a second before going away.) It's exiting THAT quickly. I checked the event viewer, but there is nothing there at all related to anything that could affect this in any way that I can tell.
Needless to say, things like Secondary Accounts are enabled. (Well, that's pretty much a given since I did try it with nearly all services enabled at once.) Oh, and the account is still set as an administrator since I had intended that SuRun be my limited account security.
Anyone have any thoughts on what the heck might be going on? I REALLY don't want to have to rebuild, waste another CDR (no RWs handy,) and reinstall again already... And that's assuming that the culprit is even related to the services. I had a nLite optimized install before as well and I don't think I've changed it around that much. I don't suppose if nothing else that there might be a way to at least get an error or SOMETHING? It's very hard to diagnose a problem when it won't even produce an error...
