In the nvidia control panel when you are under 3D Settings, and SLI Configuration, how do you make sure that SLI in enabled when you are selecting the option: Span displays with Surround..
Beneath there it says "Sli disabled"
The only option that allows it to say "SLI enabled" is when you click: Maximize 3D Performance..
I'm using 3x1 portrait monitors, and I want it to be in surround but with SLI enabled... it'll be rough trying to use 3x1 without SLI being enabled.
