Surge Strip and AVR
Nicholars
I am going to get an APC line R AVR to fix brownouts caused by my refrigerator...
I already have a surge strip, it would be a lot easier and cheaper if I can just get a IEC > 3pin UK plug adapter and plug the surge strip into the AVR, this would mean less cables / adapters I would need to buy and should also give more surge protection than the AVR on its own... But will this cause any problems or interfere with the voltage going to ground etc. if there is a power surge?
Plug socket > AVR > Surge Strip > Electronics
This would save me having to buy loads of IEC cables and an IEC > 4 way UK plug adapter so would be much easier and hopefully give better surge protection... But could this setup interfere with the surge protection if there was a power spike and make things worse?
Thanks
I am not sure APC will work in such a case, Powercom works better but check what the voltage levels are. I checked like 10 different ones and went with powercom because it was the only one that worked at such low voltages. But such situations wont give a lasting UPS, went through like 5 of them in a few years. There was also the problem of one of the phases getting mixed up with the ground but the UPS still worked but nothing else did. Kind of fooled me for a while as lights, fans, fridge (blew its circuit board) nothing else worked.. Worked for more than a day until the power company came and fixed the lines.
The UPS has built in protection so another one is not necessary.. If anything, the surge strip BEFORE the UPS works better but expect both to blow no matter what if there is a problem.
There are also line conditioners which just store enough charge for a few milli-seconds and heavier than a UPS and costs just as much but work far better in situations since they smooth the waves.. It wont work for extended cut off's.. Also it would increase your elec bill compared to a UPS as it is always on line. That 20% extra does add up over the year..
