Slartibartfast
- Sep 25, 2004
Having just completed the rig in my sig, and thinking about the fact that it cost about 5 times more than the most expensive computer I've ever owned, it has occured to me that I should probably invest some cash into protecting it, no? So I did some reading in the FAQ, and have a few questions.
1) From what I gather, a surge protector is usually built into a UPS, is this correct? I also remember reading (I think) that you usually want to plug a UPS into a surge protector, not the wall, which would indicate that there isn't a surge protector in the UPS. Does it depend on the make/model, or is it just good practice to have it behind two protectors? Can anybody clarify for me?
2) What should I be looking for in a surge protector, exactly? I want something that will provide serious protection, i.e., lightning strikes don't let the magic smoke out.
3) I was experimenting with the UPS power requirement calculator and want to make sure I'm using it right: I left the default voltage of 117 volts, as I interpreted that to mean the current coming out of the wall. I then put in 850 watts to be safe (the amount my psu can deliver), and it comes up with a recommendation of 1750va. Does this sound correct?
4) Finally, assuming that the 1750va is correct, does anybody have any specific recommendations? I am only looking for something that will give me enough time to shut the PC down, I don't need it to run for an hour once the power goes out.
Thanks for any and all input!
