Picked up a SP4 Core M3 yesterday for the silent fanless having come from previously owning a hissy SP3 i5.
Microsoft/Best Buy need to do a better job of presenting the product because most of the store SP4 demos weren't fully functional like non-working touch input, flickering screen, etc. that could turn away potential buyers that don't understand they're likely driver issues and fixable.
Knock on wood I did the major Windows 10 update first thing after unboxing and haven't had any of the known issues except for audio stopped working one time that required a reboot but it's still early on day one. Thankfully no loss of WIFI after resuming from sleep and battery life seems good that's estimated to approach 9'ish hours.
Got the SP4 with Type Cover keyboard with fingerprint (on sale at Best Buy for $129) for a pretty good deal for $939 out the door.
Really no complaints at this point except for the edge backlight bleed that's noticeable in the dark with lights turned off. For future improvements would like to see the move to SAMOLED, 8GB DRAM with fanless Core M, ~13" screen size and Type Cover with dGPU and secondary battery options.
i have heard some people have got there i7 sp4 shipped and delivered now?
Good luck to everyone waiting for various bug fixes. Mine might have been defective, not sure. I ended up needing to wipe it and reinstall Windows, at which point it got stuck in a loop that can't be recovered without service. It's headed back.
every prodcut has bugs including ipad stuff so dont worry. return it and get a new one
It's certainly fair to say that every device has problems, but I've been using computers since their inception and I can't think of a device that I've owned that was this buggy at any point in its life. MS really should have done a better job cleaning these things up before launch. Many of these issues were painfully obvious right out of the box, so it's not like they were undiscovered issues that required a large number of users to detect.
Thats not true. the ms surface pro is not as buggy as yoru exaturating and i too have been using systems since the dawn of time.
I am currently writing this on a fully updated Surface Pro 4 and it is buggy as hell. The problems include flickering (which the Nov 3 update should have resolved), sleep/resume bugs, and syncing issues with the keyboard. And yes, Hyper-V is disabled.
This is definitely one of the buggiest devices I've purchased and I've been a hardware enthusiast for 20 years. I'm going to send back and wait.
You could've done a USB recovery. Most likely lingering software issues that will be resolved. Bound to happen when making a lot changes but Windows 10 is headed in the right direction with it working like a fusion of Windows and Android.
https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage
Not sure what to tell you. My experience was terrible. It wouldn't sleep acceptably. The screen flickered like mad if I didn't have the brightness set to blind myself in a dim room. (Yes, had Hyper-V off, but shouldn't need to) The display driver crashed, etc.
I had lots of other VMWare issues on the device, but not sure if they were VMWare, Win10, or device oriented but it doesn't matter. It just couldn't serve as a work machine for me in the current state.
I've move onto a different device and I'm 100% trouble free and working again. I wasted a bunch of time on SP4. Thanks for taking the time to tell me my experience didn't happen though. /s
rubbish. come on now. your sp4 sounded fucked, all u had to do is replace with a new one
Microsoft just published an updated graphics driver to Windows update. Do a manual check updates to pull it if you prefer not to wait.
There's a subtle pressure mark on my Pro 4 screen. Is it possible to get rid of it? Or is it best if I exchange it? It's bothering me.
I got the replacement in the mail. It's worse. The bleed at the bottom of the screen is VERY noticeable. It makes my prior one look good. I hope this isn't normal. I don't want to play lottery until I get one with little to no bleed. There seems to be quality control issues.
Argh, sorry to hear that. I'm increasingly convinced that Microsoft has permanently shot itself in the foot with the hardware and software quality issues for both the Surface Pro 4 and Surface Book. Even if everything's sorted out tomorrow, they'll have a reputation for poor build quality and bugs that will take a while to shake off.
I dunno, the first gen (that I still have) suffered from various issues for a while and that did not really hinder the products popularity or growth.
Only thing keeping me from upgrading is I want one with USB type C instead of the dump proprietary charger. We'll see.
Hey guys I have a question. Does your pen's eraser button sometimes not work? And to get it to work you have to resync it again?
