My company has roughly 60 surface pro 3 tables rolled out with Win8.1ent, we have lots of issues with them. All of them are on docking stations and the major issues are with the monitors, we've had continuous problems with the surfaces not detecting the monitors. Taking the surface off the dock and hooking it back up doesn't correct the problem. Sometimes it's to the point where you have to plug the monitors into the surface directly to get it to recognize them(the newer dock). Other times resetting the firmware(volume up and power button) will fix it and other times you have to unplug the dock and just let them sit for a few minutes.
Now we are testing some surface pro 4 with win10 and are experiencing the same issues.
New surface dock
Dell U2415, U2414h and P2214H
We've tried like 15 different mDP to DP cables, have the same issues with all of them.
We are really just wondering if other companies who are rolling out surfaces having these same issues?
Are their solutions that I do not know about for these problems?
MS is zero help.
New surface dock
MS is zero help.
